andyman7931
I've been experiencing a weird rattling noise that is getting worse over time. It only happens on a warm engine, the oil temp has to be over 185 and cat temp > 500 F. Under moderate engine load (25%-60% throttle) there is what sounds like an exhaust buzzing from 1500rpm to 2500rpm. Getting ready to take it in to the dealer to see what they can diagnose. The noise has been getting worse over time, now it's to the point that I can't drown it out with music.
I poked around to try to see what could be loose and the only things I came up with were the mesh around the flex joint on the exhaust was a little loose as well as the wastegate actuator rod would slip and pop as I touched it.
Anyone have any similar issues? Things to look for/at? My car has 20k on the clock now, first started making noise at 10k.
