79TA7.6
- Joined
- May 8, 2006
- TDI
- 2003 Jetta GLS 5 Speed
So over the last week I have noticed that my car has developed a nasty sounding rattle in the front right drive train area. This rattle sounds like a heavy metal rattle, almost like something is flopping around. It only does it under no load, no back load conditions. In other works it does not do it under acceleration or if I let the car engine brake. If I lightly let off the throttle it will do it and also does it at certain speeds with the clutch in or out and trans in neutral.
I have been thinking axle as the only work I have done to the drive train is a clutch swap, but that was 40k miles ago. If the axle were to somehow come loose from the trans would it cause a rattle? I still need to crawl under it to take a look, but I have no place inside to do it and it is in the 20s right now. I am hoping to do it this weekend, but I am just after some ideas of what it could be, or if I am on the right track thinking axle. Would a bad CV joint make a rattle? I know they pop when making a turn, just not sure about a rattle.
