brandonkraemer
Recently I was turned onto the Raspberry Pi simple CPU concept and I immediately wondered if it could be reliably wired into a TDI? A few questions came up...
Is there a safe power solution for a permanent installation?
Could it be directly interfaced to the same VAGCOM port that VCDS uses but instead to the GPIO ports on the Pi, without a special converter cable?
Could VCDS run directly on the Pi, either with the Win Mobile OS or a raspian distro?
With a touch screen LCD would this be a slick "always on" VCDS integration for a ALH?
Or... is there an open source (free) tool that does what VCDS does?
Is it possible for the Pi to replace the ECU? I know... crazy talk but...
Anyone messed with these concepts?
