Mike_04GolfTDI
- Joined
- Nov 19, 2003
- Location
- Richmond, BC, Canada
- TDI
- Mine: 2019 Golf R DSG, Wife's: 2015 Golf Comfortline TDI
Edit/Spoiler: Just to help anyone reading this in the future, the solution turned out to be a new crankshaft position sensor. In case you don’t want to read to post #75 to find that conclusion. Also see post #71 for how I confirmed that the crankshaft position sensor was occasionally giving a bad signal…
After 7 years of running perfectly, two days ago my wife's 2015 Golf TDI suddenly stalled while she was at a traffic light. It started right up and continued to run almost normally.
I say almost, because now it has an occasional hesitation that can happen while cruising steadily, or during light acceleration. During hard acceleration, there is no problem.
Things I have tried:
VCDS scan. No codes in any module. Also viewed various sensors such as fuel pressure. Didn't find anything out of the ordinary. I was thinking maybe the HPFP was wearing out, but the requested and actual fuel pressures were very nearly the same under various conditions. Cam and crank speed sensors give normal readings. Turbo output is normal.
I drove it around and tried some full throttle pulls, which were fine. No lack of power, which suggests it isn't a fuel starvation issue.
I thought maybe it was oil accumulated in the intake ducting, but a 30km highway drive at 120km/h didn't change anything. During that trip it had a couple seconds of hesitation, and was normal the rest of the time. The hesitation happened while cruising steadily on the highway and caused a slight reduction in speed until it recovered.
I thought about bad fuel, but this started happening towards the end of a tank. The car made it through 90% of a tank without issue, and then this started happening. It has since been refilled with new fuel from a different location, but the occasional hesitation persists.
I'm kind of running out of ideas. The car is due for an oil change, DSG fluid change, and fuel filter change, which I'm going to do this weekend. When performed at the proper intervals, I haven't known any of those things to have any effect on how the engine runs, so I'm not hopeful that will make any difference.
I thought about perhaps a sticking EGR valve, but that would probably cause a fault code. If there's anything that might cause a fault code, it has to be the EPA's precious EGR valve.
