APT
If Ram uses the SAE spec for towing, the diesel might be rated the lowest as it has the least amount of horsepower. But I bet it tows the best in the real world within its ratings.
A recent Ram 1500 road test with the new v6 gas engine, 2WD SLT shortbox no nav, etc had MRSP at almost $38k. Some say that's more than an optioned EB F150. Something's out of wack with Ram pricing. And with the new diesel it would be over $40k.
While towing capacity may not change from the Hemi (since it is the same for the Grand Cherokee Hemi and CRD), the transmission is technically not the same. There are two versions of the TorqueFlight 8, the low-torque 8HP45/845RE (Pentastar 3.6L V6 only) and the high-torque 8HP70/870RE (Hemi and 3.0CRD). It potentially could change though since the Grand Cherokee does not have the same body-on-frame construction of the Ram.Towing capacity will not be any different from their existing 1500 trucks. This is because it will have the same transmission as their 3.6L gasser.
You will wait, it's automatic only. Perhaps a manual with two or three fewer gears and worse mpg will be offered in the future.I fear I will be waiting a while for them to marry up the Ram 1500 Diesel with a proper manual transmission.
Ram weighs about 350 lbs more than Grand Cherokee so I'm hoping for EPA mpg for 4WD Ram diesel to be minimum 18 city and 26 highway which would give real world (for me) of at least 20 city and 30 highway if not more. Towing should be at least 7,000 lbs IMHO.Diesel details: Compacted graphite iron is used for the block and the bed plate, while the twin-cam, 24-valve heads are aluminum. The V-6 checks in with 240 horsepower at 3600 rpm and a stout 420 lb-ft of torque at 2000 rpm. Go with rear-wheel drive and Jeep says you’ll get 21 mpg city/30 mpg highway and be able to tug up to 7400 pounds. Four-wheel drive rates at 20/28 and 7200 pounds. Jeep claims EcoDiesel Grand Cherokees have a potential range of more than 730 miles.
I will wager my $1 that you will NEVER get that option. Manual transmissions in full-size pickups are almost gone and tighter emissions controls means that they will disappear soon.I fear I will be waiting a while for them to marry up the Ram 1500 Diesel with a proper manual transmission.
think it'll blow?Did anyone notice that this new 3.0L Ecodiesel is using the Bosch CP4.2?
Get a MECHANICAL BREAKDOWN Policy, and learn how to install it yourself by the time you hit 100,000 miles.VW's troubles with the CP4 are known in the industry. I think it's pretty safe to say "make sure this doesn't happen to us" is in the design brief and "what are you going to do IF this happens to us" is in the purchasing contract.
Although, I would like that same gaurantee if I were to purchase the new Ram or Jeep diesels. Heck, I'd like VW to at least publically acknoweldge that there have had issues with the HPFP.
Come on, it is their livelihood which is at stake.one can dream can't they?
I'm not sure why emissions has anything to do with manual versus automatic. Manuals get better mileage, therefore should have less emissions than automatics.I will wager my $1 that you will NEVER get that option. Manual transmissions in full-size pickups are almost gone and tighter emissions controls means that they will disappear soon.
*edit*
Ford no longer has a manual-trans option for their Super Duty pickups (both gasoline and diesel)
Chevy no longer has a manual-trans option for their Silverado HD pickups (both gasoline and diesel)
I guess that leaves Ram as the lone holdout. Maybe they can still get some sales from the die-hard "I have to have a manual transmission" buyers, but I'm betting that within the next couple years their 6-speed manual will be gone.
More often than not, automatics are rated higer mpg by EPA than manuals.Manuals get better mileage, therefore should have less emissions than automatics.
Transient events which include shifting gears are a primary emissions challenge for diesel engine certification. The automatic transmission significantly reduces or eliminates the emissions spike when shifting gears thereby making certification easier to achieve.I'm not sure why emissions has anything to do with manual versus automatic.
There is so much computer control over things in engines that all the Engine Control Unit stuff is interfaced with the Transmission Control Unit on modern, computer controlled transmissions. It's a total Powertrain Control Unit that controls everything from throttle butterfly opening (in diesel engines that feature a throttle, for tumbling action and air mixing), injection timing, fuel injection quantity, valve timing, shift timing, etc.I'm not sure why emissions has anything to do with manual versus automatic.
Or about $26,000 today...See, I'm not even that old and I find that to be outrageous. Right around 2000 you could get a stripped down work truck Ram 2500 (vinyl floor, manual windows, etc.) for about $20k.
Yes. The driver might actually be (gasp) in control of their vehicle......With a manual transmission there is no computer control over what gear the user selects. There is the possibility that the driver could lug the engine low in the operating speed range where emissions are higher than would be with proper gear selection, or rev the engine higher than necessary. ."
Fuel system pressure on 2009 and later TDIs (CBEA and CJAA) is 1800 bar, which is just over 26,000psi, not 29,000.think it'll blow?
My '07 MB 3.0L has never recorded over 24,000 PSI on the fuel rail since I've owned it. It's max rating is 26K. The VM 3.0L is rated for 29K PSI - same as my '09 TDI
which went kaboom
Right, but the government is in control of allowable emissions limits. So the manufacturers have a choice to meet those limits . . . or not sell vehicles.Yes. The driver might actually be (gasp) in control of their vehicle......
