Is there any programming to be done when swapping identical radios?(RCD510) Obviously the Sirius receiver number needs to be given to Sirius, but what about other features? The reason I ask is, the dealer exchange includes installation and programming for $600. The service writer said that includes $120 in labor to pull the old to get the serial number, put it back in, order the radio, and pull and replace with the new. She threw a number of $400 in one of my e-mails. I understand the labor, but is there really a need to reprogram an exchange from the dealer? I can easily swap it myself.
Donald
RIP OFF RIP OFF.... First the serial number can be had by using Ross Tech Cable... which you don't have, but never the less it takes a few minutes. I suspect a few minutes or an hour, they are going to charge you a full hour. RIP OFF, but par for the course with dealers. You really don't need the old serial number if you are going to replace it with a used unit....
The actual removal and replacement of the radio is 30 minutes. Go look on Youtube. You need a non metallic tool to get the plastic surround bezel off. Then a few screws and connectors that pop off. You can do all of it sitting in the passenger seat.
There is no programming I know of as N41FE said. If you buy a used radio... GET THE CODE!!! I am not sure if the radio is new, I guess they have to CODE it? This should take less than 10 minutes for a tech even if reprograming is needed.
$400 is bad value, $600 is ridiculous labor. I can see at most 2 hours total, at $125/Hr..... $250..... However $600 or even $400... hummm. Since the price changed it shows you have arbitrary the labor is. If you lived nearby I'd do it for free. I would ask to talk to Manager of the dealership. If not call VWoA and ask to speak to customer advocate.
Consider skipping dealer. Try and find a good used (OEM VW, with code, North American Radio spacing), get a warranty. eBay gives a guarantee. Ask seller to up the return period to 30 days, so you have time to install it. Then find someone local to install it... like a local stereo shop... should do it for a $100.
