Dakota2004
Is it normal for the radio to stay on until key is removed? This is a 2002 Jetta TDI. My other vehicles, the radio will stay on until the door is opened.
I also beleive the radio will shut off if left on for one hour. I know it is not the same thing but there is a feature. Unlike other cars that the radio stays on all night...Thanks for the quick reply. Is there any way to make the radio turn off when the door is opened? I leave my keys in the car when I’m at home and would like to just turn off the vehicle and get out.
As said, the radio stays on until the key is removed or one hour passes. If you leave the keys in the car (!) and walk away, how about just pushing the radio power button. This will turn the radio off regardless of the key or door until you turn it back on. If you didn't get an OM with your car, try getting one on ebay or elsewhere- it will have answers to lots of features- or search for "favorite hidden features." Remember, the doors will self-lock in some circumstances, so make sure you have access to your keys!Thanks for the quick reply. Is there any way to make the radio turn off when the door is opened? I leave my keys in the car when I’m at home and would like to just turn off the vehicle and get out.
Jason,You can also program your locks to unlock when you pull the key from the ignition
-Jason
From Here My car locks at 10mph, unlocks with key out of ignition, all doors unlock with one press of the remote. Just the way I want it46 - Central Convenience: -- KWP1281
Only on vehicles with power windows. VAG-COM fine. There are numerous options/ features that can be set.
Selective Unlocking:
[Select]
[46 - Cent. Conv.] (35 - Cent. Locking for manual window cars)
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding.
So, if you have a 2-door 2002 GTI that is coded for selective unlocking (00064) add one to make it 00065 so that all doors unlock with one press of the unlock button.
Lock/Unlock Horn/Flash:
[Select]
[Adaptation - 10]
Channel (03..08)
Adaptation Value (1 = on, 0 = off)
[Save]
Channel 03 Auto Lock
Channel 04 Auto Unlock
Channel 05 Unlock, horn sounds
Channel 06 Lock, horn sounds
Channel 07 Unlock, turn signals flash
Channel 08 Lock, turn signals flash
So, where do you live exactly?...I leave my keys in the car when I’m at home and would like to just turn off the vehicle and get out.
"Lansford, North Dakota "So, where do you live exactly?...I leave my keys in the car when I’m at home and would like to just turn off the vehicle and get out.
Ever watch "It Takes a Thief" on Discovery? The guy LOVES cars with keys in or near them, garage or not.I guess I should add that the Jetta is in a locked garage.
OK, maybe I exagerated a bit. Since the Uncle Sam sent you there, you probably aren't related to to anyone either.Come-on now, Lansford has 262 people last time I counted. I am originally from Kalamazoo Michigan but the military thought I need to be in North Dakota
Hey guys, you hear that!!! His jetta is only protected by a "locked" garage door! Let's jack dat shi!I guess I should add that the Jetta is in a locked garage.
One of us has a broken car. Mine doesn't do that.I feature I found on radio.
Once key is removed turn the volume up a bit then the radio will play.
Once the door is opened the radio will quit.
