Radiator question
Instigatr
NE WA State
03 Golf 2 door MTM
Hello all
Have a question regarding the radiator in my 03 Golf. Noticed it has a minor seep, low on the driver's side. And as we all know, leaks rarely fix themselves before they run out of whatever fluid is leaking....
Anyway, idparts lists 3 different radiators for my 03. Near as I can tell, it's just different brands, for up to double the price of the first one. Maybe this is more of a question for IBW, but anyone have any recommendations on which one? I sent a question on the idparts website, but it has gone unanswered for awhile now.
Car is slowly getting into what is considered good mechanical condition.
Aaron
csstevej
north nj
Give them a call….. they are pretty good at picking up the phone.
Personally you should be fine with any of them……
Johhny04
Markham, Ontario
2003 Jetta TDi
Go with a name brand and save yourself the headache, purchase the 4 radiator support brackets for each side now. If its never been replaced before, the radiator support brackets for sure are worn out and will need to be replaced.
TDI Jim
Gaithersburg, Maryland
1996 Passat, 1996 Passat Variant (RIP), 2002 Jetta Wagon, 1995 Passat Variant TDI conversion brought back from the dead, 1997 Passat Variant project, and returned 2014 Passat
The off brands can have issues with the plastic piece extension connection leaking on the lower radiator hose. I would go valeo or nissens, but can understand when money is tight as we have all been there.
I would go for one of the OEM suppliers, which is usually going to be Behr/Hella or Valeo. These radiators rarely fail on their own, it is usually a result of a crash with something (doesn't take much, everything is plastic), so you may want to get the front of the car apart FIRST to see if you need anything else.
It is quite common for me to get one here in the shop that the owner thought was just a small "bump" against a curb, and they end up needing a new lock carrier, a new condenser, new radiator, all new radiator mounts, a fan mount, and maybe a couple other small bits.
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
Hello all
Aaron
Where exactly is it leaking from? Pics?
Zak99b5
Albany NY
2003 Jetta TDI
I'd use the best you can afford. It's a bit of a pita. Definitely have some long bolts to support the lock carrier in the "service position."
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
I replaced mine on my first TDI (99.5 J). Bought the cheapest one, never had any issues in maybe 6 years, car was totaled. It was made in China. If you plan on keeping the car a long time, definetly get the Valeo. Doing your own work, $90 is peanuts.
benmarks
Portland, OR
2004 Jetta GLS Sedan Platinum Gray
Another vendor option is Cascade German in Portland, and they're usually good about picking specific good aftermarket vendors. The one I got was Nissen.
Another option, though not the most economical, is Darkside's all-aluminum radiator which removes the plastic parts. This might be better as an upgrade after you've done other performance upgrades though, if that's something that interests you:
Instigatr
NE WA State
03 Golf 2 door MTM
Didn't take any pictures at the time. Was last fall when I noticed it. Money was an issue at the time, and it was real minor. One of those things were I filed it in the memory bank and figured I would replace it as soon as I could. Now money is available and the car is getting some much needed love.
As far as oilhammers comment, been there and done that more times than I can count. Thanks for the advice.
On Darkside development radiator, I see they are a UK company. Seems like shipping would be kind of high, but I am real partial to ordering it.... There's been many upgrades done to the car, some of which I am sure that I'm unaware of.
Working on replacement of the radiator in my 94 gmc truck as we speak because the side tank is failing. Found a really nice all aluminum tig welded radiator for it at a very reasonable price.
As always, I am very thankful for all the advice. Someday I hope to be able to help the community on here as much as you guys have helped me.
Aaron
GlowBugTDI
Cambridge, MN
2001 Beetle GLS TDI (BIODSL). Glow Bug TDI (sold)
Could run to the walmart and get best brand stop leak. I have never used in a vw, but i have in a leaky s10 and it worked short term while i owned it
benmarks
Portland, OR
Darkside is a UK company, but they ship a ton of stuff to the US. A lot of us here use them. They usually use DHL. I just entered my address to estimate the cost to me on the west coast, and it is $69, which for something that big is a pretty good price whether of domestic or European origin.
UhOh
PNW
2000 & 2003 Golf GLS
Original lasted 19 years. If that's not long enough then MAYBE go with something up-scale. I'd say it's more about quality control than materials, so OEM (be it plastic or whatever) should be fine.
