Radiator Fan Funny Behavior
Gig Harbor Washington
2005 Jetta TDI bew
So my radiator fans keep turning on and off every 5 seconds. I replaced the radiator fan control module and the sensor switch and they still do the same thing. I noticed when I unplug every thing and plug it back in everything works normally for a couple minutes. I cleaned all the connections and both fans work fine. Does anybody know what it might be.
The only thing I can think of is my ecu.
Could it be something with my AC.
Whenever I turn my car off the AC light turns on.
super1
NY
none
Are you saying that they stay on when car is off? if so check all fuses
super1
NY
none
The fans just keep turning on and off.
And I already replaced the control module and sensor switch.
I checked the fuses and there all fine
Is the A/C switch in the off position? Maybe switch is sticking?
seems like something is energizing A/C circuit check fuses on top of battery the 3 little ones I think furthest left, those boxes melt lots of times
P2B
Toronto & Muskoka, Canada
It turns off when I push it in but when I push it back out it turns off again
That doesn't compute :oops:
Have you tested the fuses at the end of the dash by the driver's door? Specifically fuse #16.
The fuses look fine
Visual inspection of fuses is not reliable, test them with a meter. The fuse holders on top of the battery are often an issue as opposed to the fuses themselves.
