Sam1212
Hi everyone was trying to get the ac working In my 2001 Jetta tdi with 285k.
I know that If the radiator fans won’t turn on the ac will not work so I read the thread on here about troubleshooting the radiator and condenser fans and I’ve ran into a dead end.
1st issue
When I press the AC button no light turns on, would that have something to do with the burnt out resistor that controls the fan speed, before my fan speeds stopped working the ac button would at-least light up obviously no ac though.
2nd issue
Since I can’t do the trick with turning the ac button on and seeing if the fans turn on I went to jumping the fans directly from the battery, big fan nothing little fan turns on with direct power but not in normal operation, after a drive where engine got up to temp I hooked up a meter to the output to the fans from the control module (with car still running) and nothing was reading from either one of them. Big or small.
What would the next step be? Trying to fix the first issue or replacing the control module and seeing what happens? Or something completely different. I’ve already checked the green fuses on top the battery as well and they look alright not sure if there’s a different way to tell if they are burnt out? Obviously know I need to replace the big radiator fan.
1st issue
2nd issue
