shirish_bh
- Joined
- Nov 9, 2000
- Location
- Auburn Hills , Michigan
Hi,
I have a question regarding the AMSOIL bypass oil filtration system.
It takes approximately 10% of the oil and passes it through the filter. This means that now the engine is getting only 90% of the oil that it was getting before the bypass filter was installed.
Is this lower oil supply detrimental to the engine in any way?
Is there any warranty issue with the installation. Theoretically VW can attribute an engine failure to the lack of sufficient oil (only 90% of design value).
Is there another bypass system that uses a pump of its own? Or will it be too costly?
Thank you for your help.
