Question on ALH turbo oil return passage inside block
Rembrant
Canada's Ocean Playground
2013 Golf TDI DSG
Question on turbo oil return passage inside ALH block
Hi Folks,
Would anybody happen to know how the oil is channeled in an ALH block once it leaves the turbo oil return line? Is it just a dedicated channel or passage that pours directly into the oil pan?
Raweaver_410
Cordova, MD
Mk4 Silver Golf TDI 5spd, Mk4 Red 2.0 Jetta Auto, Mk2 Blue Diesel Jetta 5spd, Mk1 Sandy Diesel Jetta 5spd
It literally pours in from the block to the bottom of cylinder #2 I can post a picture if you need it.
Rembrant
2013 Golf TDI DSG
Well that would be cool if it's no trouble. I have an issue with this port in the block on my Beetle, and when I remove the old banjo bolt and return line, I'll have to clean things up and I may get some dirt/debris and cleaner in this hole. If it's just going straight into the oil pan, I don't really care. I can remove the pan and clean it out. I just didn't want to be forcing the dirt/debris into a place in the block where it would cause a problem. The oil pan I can deal with.
A picture would be great though. Thanks for the reply.
Rem
Rembrant
2013 Golf TDI DSG
http://s16.postimg.org/8db8gzjk5/block.jpg
I had circled it but for some reason its not uploading with my edit. But you can see it in cylinder #2
Perfect, thank you. That is exactly what I wanted to know (and see). I can even see the end of the return line union fitting on the inside of the block. It's just a threaded hole, straight through. Piece of cake.
Thanks. Rem.
Raweaver_410
Cordova, MD
Thanks. Rem.
Glad to help good luck with your project, cheers.
