pedroYUL
- Joined
- Sep 8, 2011
- Location
- MI, USA
- TDI
- 2015 Passat CVCA; 2015 GSW CRUA; 2012 wagon CJAA; 2004 wagon BEW
Maybe this is even a 101 question, I admit having much to learn about transmissions anyway.
Car: 2015 Passat SE 6MT 93k miles. New to me since maybe 80k.
Issue: I don't recall noticing this when I test drove the car, but after a long drive back home and some more driving I noticed the stick needs a slight pressing left so that 1st and 2nd engages (1st gate), more so 1st than 2nd.
Car developed a CEL and I took it to a dealer to get the 2nd part dieselgate fix done. I did mentioned this issue to the dealer and promised to look into it, which I'm not sure they did. In any case I asked again, and they say it could be an issue with the actual gearbox. I asked if they could adjust the cables, and they said shift cables had no adjustment
Anyway, I later did try to adjust the shift cables and found the nut at the shift tower loose. Some light wrenching later and it seemed to shift better. But with time it got back to needing that little pressure left.
Big question: is there really something wrong with my transmission that warrants a new one? Something else that could be wrong?
Thank you people!
Thank you people!
