Tempestkic
Hi guys,
I just replaced my fuel temp sensor on my 2002 alh injection pump. I watched one or two videos on YouTube and then went for it as it seemed pretty easy, but it is my first time working with an IP and didn't realize how finicky they can be.
There was quite a bit of crud built up on the quantity adjuster when I opened it up so I took some brake clean and a toothbrush and gently scrubbed the electronics in there. I had the bright idea to try and remove the top part of the QA electronics to make cleaning easier and they appeared to be held in place by a couple small screws. I removed the screws and realized that it was not so simple to disassemble. Rather than dig further into it I put the screws back in but i noticed that the copper (‽) thing on the left side of the sensor had shifted when I had loosened the screws. I referenced a photo I saw online which had this copper thing moved as far towards the front of the car as possible, so I matched that. I reinstalled the top case of the QA without realizing there was an additional adjustment with this piece. Anyways I now have a p1562 (upper limit quantity adjuster) code. It idles a bit rough at idle now and when coasting, fine under throttle. Ran great before I messed with it despite the fuel temp sensor code.
I have read a number of threads on here but haven't been able to find anything on how to clear this code by adjusting either the copper thing inside or the top of the case using the hammer method. Any advice would be appreciated. Thanks.
I don't currently have access to a vcdm, but do have a cheap obd2 reader.
