arjax
In trying to solve my p0087 issue, I decided to pull the fuel metering valve to check for metal shavings. Thankfully there wasn't but now the car won't start. I didn't tinker with HPFP only the fuel lines that connect to the fuel rails to move them around while getting the intake manifold off and on. I did run the lift pump a fuel times but I didn't open the low pressure lines.
I have this also cross posted on Ross Tech's forum. Here's a link to the post. VCDS shows no pressure being made and the engine is spinning at 230 rpm.
I do have a fuel rail cap (only one). So I tried capping off each injector one at a time to see if one of them was leaking. No change. There is some fuel that comes out when I removed the cap so some fuel is being transferred.
The only other thing that I have done to the car was I had the ECU send off for a bench test. A problem was found related to the EGR temp sensor.
Thanks in advance for any help. Here's the code from VCDS. The graph below is from two times I tried to start the car.
Code:
21233 - High Pressure Fuel Rail
P00C6 00 [01100101] - Minimum Pressure Not Reached
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 259696 km
Date: 2024.01.29
Time: 09:56:35
Engine RPM: 228.00 /min
Normed load value: 100.0 %
Vehicle speed: 0 km/h
Coolant temperature: 12 °C
Intake air temperature: 13 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 10.600 V
Unlearning counter according OBD: 40
Fuel temperature: 14.3 °C
Mean injection quantity: 31.11 mg/stroke
Rail pressure regulation: status-Bits 0-7: 0
Fuel high-pressure: actual value: 2500 hPa
High fuel pressure: specified value: 300000 hPa
Pressure control valve adaptation factor: 1.1058
Fuel level: 43.00 l
