eddie_1
- Joined
- Dec 27, 2004
- TDI
- Jetta Wagon 2003 TDI tuned to 170HP, A6 Wagon 2008 TDI 2.7L tuned to 340HP
I was wondering if any one had a good idea on what the waveform looks like on newer cars (but before LEDs) for driving the std. DRL bulbs? My understanding is that the DRL is driven by PWM (Pulse Width Modulation) on my 2008 Audi for example i.e. on/off signalling and the duty cycle is used to control the average power provided to control the intensity, for example 80% light. The issue is that there are many after market LED based bulbs now like ba15s that can be inserted in the same bulb socket. I tried a set of these but they died after a couple of months. I've seen many many people having the same problem depending on car type. The problem seems to be that the DRL signal is not readily usable for the LED array. The LEDs require a constant current source whereas the PWM is a switching voltage. When my LED failed I opened one up and saw there is a circuit board in front of the LED array. From the internet I found the datasheet for it. Basically it was a DC to DC converter which is not ideal because the PWM signal is switching and the DC/DC circuit seems to have died due to possbile high power switching effects from the PWM signal, whereas the LED Array itself was fine. In the lab I noticed the LEDs need max 350mA to give off the maximum light. The DC to DC Converter could take in any voltage and provide the constant current, but continous switching at input it is not desgined for imo. This comes back to my original question if someone really knows the characteristics of this PWM signal for DRLs. For example the amplitude, frequency and duty cycle %? Also what the driver stage of the DRL driver in the car looks like? If this info is known, a circuit could be easily designed to filter the PWM signal or use it to switch a relay etc, otherwise it would be more a trial and error approach. In fact if I cant get more info on this signal I was thinking of measuring it with a scope.
