honda_vtec2
A short while ago i was driving/cruising doing 80kph. I felt a slip in the power band and started hearing lifter clatter. I pulled over to the side of the road and checked my timing belt. It was slack, still in good condition. After getting the car towed home. I then inspected the tensioner, and the internal springs were damaged. Upon removal the tab was still in it's slot, but the larger tab on the end was bent to hell. I'm not too sure what happened here........After i timed the engine up. The crank and ip were still timed but the cam was out, which caused camshaft and lifter/bore/valve damage. This tapered end was hand sanded and cleaned with brake clean and torqued to 42/ft lbs the last time i did the job.
All timing components were changed 40k ago. Everything was torqued to spec
Question:
Anyone have any ideas what might have happened.
Note:
I've done this job 3 times with new parts since i've owned the car. Roughly putting 80k on it since. The 3rd time around, i rebuilt the crank and hopefully secured it in place, since then it hasn't shifted or loosend. OEM parts have only been used on this car regarding the tbelt components. Cam was original and lifters were INA which had 40k on them as well.
The car is fixed and being driven now, but i still have no clue what might have happened.
Question:
Note:
