aNUT
Resolution
I have a car in the shop I'm having some trouble with. It's an '06 Jetta TDI with manual transmission, engine code BRM.
The customer reported that it died on the highway driving home after work. After waiting a few minutes, he restarted it. It drove absolutely fine for 3 minutes, then died again. He repeated this process until he got home. After a cursory inspection for obvious problems he brought it to me. He determined that the battery connections are tight, the battery has good surface voltage, and that the alternator charges the battery at ~14V.
I immediately duplicated the customer's complaint, however, it appears that the car shuts down, rather than dies. The EGR throttle/ASV closes as the car cuts fueling just like if the ignition were turned off. After waiting ~5 minutes, the car starts, runs, and drives normally for another 3 minutes.
After the car turns off, the MFD stays lit, but when I cycle the key to restart, the engine does not crank, and the MFD stays blank. The only activity on the instrument cluster when the car is in No-Crank-No-Start (NCNS) mode is that the DRL light is lit when the parking brake is off, and the backlighting on the cluster is on if the headlight switch is on.
I also found that the engine need not be running for the car to enter NCNS mode. If I switch the ignition to 'on' but do not start the vehicle, after 3 minutes, the car will not crank.
I can communicate with any module in the car when it's working with VCDS, but cannot establish communication with anything when the car is in NCNS mode.
There are no fault codes stored.
I have verified that: the battery has voltage and terminals are tight. I have verified all accessible grounds in the engine compartment.
For those with manuals; I have verified that the following fuses are intact:
SB6 SB10 SB13 SB15 SB17 SB23 SB25 SB26 SB27 SB28 SB29 SB30 These are located in the box next to the battery. I have also verified fuses SC1 SC15 SC25. These are located in the box mounted into the side of the dash.
I have inspected the plenum area where the ECU is housed and found no water or evidence of rodents.
I have inspected the wiring for the cam and crank sensors, and found them to be intact.
After starting the car and waiting for it to shut down, I found no excessive temperatures on any of the relays; both under dash or on the fuse box next to the battery.
I'm a little stumped as to what to investigate next, and any help would be appreciated. Obviously, we suspect some sort of current overload, but are at a loss as to where to look next.
