Puzzling ABS fault after B5 manual swap
runonbeer
Maintenance EnthusiastVendor
Austin, TX/Chapel Hill, NC
'00 Golf 02M, '10 Golf 02E, '02 UTE 02M
Hi guys, I've got a Passat here that I just put a 5 speed manual trans into. Everything works great except I have a fault in the ABS module that I can't get rid of. Its an early Passat (09/04) with ASR rather than the seemingly more common ESP.
I have recoded the CAN gateway to 00006 many times. I have cleared the fault many many times. I've tried different soft coding in the ECM.
I just ran an auto scan. Can anyone point out the mistake I'm making here? I am particularly puzzled by the ECM label "fail"
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Friday,16,May,2014,18:54:43:32736
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWCE63B25E051170 Mileage: 238270km/148054miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 038 906 016 K HW: 028 101 198 2
Component: R4 2,0L EDC G000SG 6483
Revision: 12345678 Serial number: VWZ7Z0D0146771
Coding: 0150031
Shop #: WSC 25157 444 58758
VCID: 1C3D2061DCD427FE67F-515A
No fault code found.
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 8E0-614-111-ASR.lbl
Part No: 3B0 614 111
Component: ABS/ASR 5.3 FRONT D00
Coding: 00012
Shop #: WSC 05314
VCID: D3AF0B5D218A2886F65-513C
1 Fault Found:
18263 - Powertrain Data Bus
P1855 - 35-00 - Software Version Monitoring
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 05311
VCID: 244D1881B4A41F3EDFF-513C
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F67E7ADED62AC6632D-515A
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 15235
Shop #: WSC 00000
VCID: 27570F8DC592F426FAD-513C
WVWCE63B25E051170 VWZ7Z0D0146771
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: F0E5A4D1B0DC739EEB7-513C
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 80 Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 05311
VCID: 3777DFCD153264A66AD-4B18
Subsystem 1 - Part No: 1C1959801
Component: 80 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 80 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 80 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 80 Tõrsteuer.HR KLO 0202
End ---------------------------------------------------------------------
themightyquinn
1999 New Beetle Black
The problem is that early ABS system on Passat will not work with Euro software version.
You have to use USA software version.
PM me for more info.
So is this implying that the tuner used a european software base to do the flashing and thus there's no way to fix it on the user end without changing to a different tuner? I have the same issue. It's not a huge deal, I can live with the light I suppose (or at least desolder it), but if it's possible to easily fix it I would like to -- the swap kind of feels unfinished until the light is out.
jetta 97
Dallas (McKinney) ,TX ,USA
2 X Jatta MK5 2006
I sent you PM.
