NarfBLAST
Push Button Start Version 3.0
The Volkswagen has been back on the road (details here) and it has been tonnes of work and tonnes of fun but there is one problem I guess I have been avoiding. I have had an intermittent "no crank" problem. I have tried, "everything else" and I guess I convinced myself that my circuit was "working" but when I got down to looking for the "starter relay" in the car I realized that there wasn't one and that all the current to fire the starter solenoid had to pass thru the ignition switch, or in my case, the undersized relays I had wired in place of the ignition switch.
It is time to re-visit this modification and replace all the relays.
I am not sure what the amperage rating is on the relays I used, I will check when I have a chance to pull them out, but this is what I am putting in:
20/30A relays on the accessories side
30/40A relays on the starter side
I believe these are rated for working/peak amps. Also, all of the wires are 14 gauge and there will be no solder joints.
Looking forward to installing this in the car after the kids go to sleep tonight:
