NarfBLAST
So I try to start my car about a month ago and I feel the key go limp. I snapped the little metal tab that engages the ignition switch (the white thing between my left thumb and fore finger in the following picture).
Does anyone know if the metal tab that goes into the white thing comes with the ignition housing or the lock cylinder? I tried to get the lock cylinder out following the "stick something in the hole and pull" technique described in the Bently manual but gave up. This is way more fun anyway:
The chrome toggle on the left is wired to both "key in" and "ignition on" contacts on the ignition switch wiring harness. I could have separate switches but I did not have enough room. The only loss is that when I shut down the engine the radio immediately shuts off and the interior lights immediately come on as if I shut down and removed the key right away.
The toggle on the right is wired in place of the "on while running but off while starting" contacts of the ignition switch. I just turn it on after the engine is running. It controls the AC, fans, DRLs, wipers and turn signals, and probably more this is just what I have discovered so far.
It is not possible to start the car without the key in. The immobilizer has not been modified and also you need the key in and turned forward to unlock the steering.
The starting sequence is:
Insert key and unlock steering
Set left toggle to "RUN"
push START button (vrrrroooom!)
Set right toggle to "RUN"
The stopping sequence is:
Set both toggle to "STOP"
Remove key
So, does anyone else have a push to start button on their TDI? Please post pics!
edit: Now in version 2.0 (from post #16 onward)
It works! Video!
1:35 Push Button Ignition on Thrustmaster Shifter
edit: click here for the "Thrustmaster Shifter" thread: http://forums.tdiclub.com/showthread...43#post3050843
Remove key
It works! Video!
