Turbo Steve
- Joined
- Jan 11, 2000
- Location
Simplified Version of Pumpe Duese 101
To simplify things for our valuable newer members of Fred's good Forum, the Pumpe Duese (PD) Injection System is just another way to increase injection pressure to the TDI's fuel injectors in order to vaporize and atomize the diesel fuel spray more effectively. (Note - Current TDI Injection Pumps already produce about 16,000 PSI with the 10mm injection pumps plungers for manual transmissions and up to 19,000 PSI on injection pumps with 11mm plungers in auto transmissions.) The PD Systems are so powerful that they almost double the PSI to a whopping 29,050 PSI +/- of fuel pressure.
150 HP / 320Nm Torque
Pumpe Duese engines are basically upgraded with 4 unit injectors, with each cylinder having its own high-pressure type pump housing 10mm or 11mm plungers. These unit injection nozzles, which are built into a single unit, also eliminate the need for the 4 fuel lines running from the injection pumps of current North American bound TDI's.
In short, Pumpe Duese is simply the name of the fuel injection system within VW's family of TDI engines.
Moreover, this upgrade in injection technology is also supposed to result in a much better burn efficiency with lower emissions to boot.
Keep in mind that while the PD is still a TDI engine, it only has a different more-powerful injection system than what we currently have. VW claims that this type of fuel system is smoother running, except on very hard acceleration or at lower RPM's when the engine is over-stressed or lugged (only then is the PD louder than our current TDI). Other than that, the engine is generally supposed to be noticeably quieter than the currently TDI's available in North America.
One reason why it might be "noticeably quieter" is because the PD system has a better combustion process and needs less compression to get the job done in an efficient manner.
Lower compression with increased injection pressure, means less noise and improved acceleration via more torque.
One drawback to the Pumpe Duese Injection System is the proverbial retarding of the injection timing, which VW uses to further lower NOx emissions - again following the advertising ploy (California & New York) or pattern they're currently using in North America.
See also these excellent articles on: "The Clean Future of the Diesel Engine", Tuneline , The TDI Club's Forum FAQ , and "VW Adds Two New TDI Offerings To the European Lineup".
[ June 07, 2001: Message edited by: Turbo Steve ]
