My VW would not start this morning. The little indicator window was clear, which on the sticker it says clear = change battery, black = good. The outline for the service port on each cell was barely perceptible under the sticker, so I decided to peel back the stickers....and sure enough, underneath were 6 caps like a normal non-maintenance free battery. After removing the caps, each cell was in fact pretty low too. Got some distilled water and filled it back up, jumped it, and went for a nice 1hr drive to get it charged back up some. After getting back from that, the little indicator window was black again. Started it up a couple other times during the day on subsequent trips, and so far so good!
This little tidbit has been stated before on here, so this is just a reminder. If you are a DIY type and your battery is out of warranty, or else don't mind the loss of it by peeling off the top stickers...check and stay on top of your water levels!
