Provent 200 with dual CCV inputs
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
Well I was an Old Navy CCV tester, then I bought the tdiwagonguys filter, now I have the Provent 200 and it is just awesome. Absolutely no oil in the hose going back to the intake. Note the hose from the hockey puck was up until 2 weeks ago coming from the Old Navy CCV filter which is why it is a little cleaner.
I have the drain of the Provent running through a tube down to the ground, maybe at somepoint I will return it to the sump, but then again maybe I will never get to that.
Gothmolly
Providence, RI
2002 Golf
Watch for vibration rubbing the CCV puck against the air intake hose. Mine almost wore through before I wrapped some stuff around it.
Choupette98
New Brunswick ,Canada
Beetle ,98 ,Silver
A simple trick is to turn one end of the tube where's the clamp until the tube will twist a bit and clear the puck ... Have to make a right or left turn you'll see by yourself ... but i think that the filter side is easier to work with !
Mine bust right throught before i notice :mad: got to glue it back !
N_J
Vancouver, BC
VW 2002 Golf 5 speed TDI Indigo Blue Pearl
Bump for the tube twist trick.
Been struggling with this for a while.
jjraymo
Maple Grove, MN
ALH Wagon
Any reason you don’t just connect a hose from the ccv to the oil fill? Just curious...
