Stealth TDI
Pre-Forum Veteran Member
Hi,
I've been quietly prototype-testing UPsolute's Stage III Enhancement for A3 TDIs. I am the first to do this to an A3. So there are still a few kinks to iron out. But I'm still ready to go public (keep in mind I've agreed not to share specifics yet). I'll use photos and dyno plots to tell the story (a picture is worth a thousand words...). Some plots are from real dynos, mine are from VAG-COM plots (which have been found to come pretty close). All have been replotted by Excel to make them pretty. Also, all graphs are plotted at the wheels. Here we go:
Here's a stock B4, rated at 90-bhp and 149-ft/lbs...
This is my engine bay in stock form (engine cover removed)...
So, UPsolute introduces a turbo that's just a little larger than stock...
It wouldn't fit unless we installed it in pieces...
But we evenually got the darned thing in there...
Here's the finished product...
And a closer look at the turbo...
Let's not forgot my exhaust "system"
"Yeah, yeah... So what kind of power does it lay down?"
By now, you're thinking about scrolling up to see how it compares to stock. Here you go...
And here's how it compares to my old Stage II setup...
To keep things in perspective, I created these shootouts between the three A3 powerplants...
My VAG-COM pull was done in third gear. Really, I think fourth gear pulls harder. But a fourth gear VAG-COM run would get me to 100-mph in short order. So, I'll have to save a fourth gear test for when I hit a real dyno. I have a few other dyno comparisons (for fun) at http://www.StealthTDI.com/DynoPlots.html.
The turbo doesn't spool as quickly as the old one. But it certainly comes to life in the region in which most people hot-rod. I can't prove it; but my car feels stronger than my Passat w/1.8T (stock). And my fourth gear 60-to-90mph sprint has been reduced by 20% to 8.2-seconds. Considering that my fuel pump is stock and I'm not using Kerma's injectors, I'm pretty happy with the performance. The car is pretty potent for a lowly A3 and still manages 50-mpg with easy highway driving. The only thing I haven't tested is just how it handles an autocross course without the low-end grunt I used to have. I sort of miss the low end torque. But a change in driving style keeps good torque fairly handy. More photos of the install can be seen at http://www.StealthTDI.com/StageIII.html. I've already been improving the turbo inlet... just a little more fabrication and it should provide VERY little restriction...
Drivability is good. There's NO surging at any speed. Smoke is up when I'm into the pedal. But it's pretty easy to manage. It comes in handy for dealing with tailgaters.
Take Care,
Scott
Take Care,
Scott
