Projector headlights for '09 Jetta?
LBJ (Laser Blue Jetta)
St. Paul, MN
2009 Laser Blue Sportwagen w/DSG
I've got an '09 TDI Sportwagen and am very disappointed in the headlights. I drive a lot in winter and these lights have a lot of vertical light scatter which is very bad in snow. Has anybody found a projector headlight retro kit that works for the '09? All I've seen are ones that claim to install up to '08.
I'd consider the fog lamps but unless I could just run with fog lamps and the marker/tail lamps, they wouldn't do me any good if the DRL can't be turned off.
I see that ECS tuning has a light switch with more lighting options that ON/OFF but it seems to require VAG-Com to make work and I'm without access or knowledge of such. So, I'm hoping for a simple headlight replacment.
St. Paul, MN
'09 JSW headlights
Thanks for the reply. I wasn't sure what year range used the same headlight shape. I'm not so sure about the 2010, however. I saw one at a local dealer last week and the front end appeared quite a bit squintier with a narrower headlight unit that was more pointed as it met the grille. It was still a reflector style but the innards had changed from my 09.
I'll check into the Hella as it is my light vendor of choice.
andreigbs
Walworth Co., Wisconsin
N/A
http://tdiparts.com/catalog/product_info.php?products_id=1028
For $1000, OEM cannot be beat.
ECS Tuning
Wadsworth, OH
Volkswagen
Hella Mk5 Halogen projects are basically the same housing / projector as the OEM HID with a halogen bulb. The will accept drop in HID kits as well.
MBoni
Atlanta, GA
2009 Jetta Sportwagen
I've got these lights in my 09 JSW, and really like the way they look & function. (And ECS Tuning is a good source.)
However, if you are having scatter problems on snow, you might look into getting a set of fog lights with yellow bulbs. I've heard a number of sources that say the yellow light is better on snow or wet roads. ECS Tuning also supplied my OEM Projector fog lights (and a wiring harness), might be worth looking at.
If you go that route, you'll probably want to add a Euroswitch, and program the vehicle so that you can run on just fogs without headlights. If you can find someone with vag-com, it's an easy change to make.
