mrfrankmrfrank
So I am starting to plan out my path to upgraded mod bliss. I am trying to plan an order of purchases / upgrades and I am looking for advice. I start thinking.. ok, I'll buy this, then this, but what about that then this and I end up fearing that I need to buy everything at once or my engine will end up running quite poorly. Please keep in mind that I am a severe engine novice and will be trying to learn as much as possible. I read some of the things you guys post about nozzles and clutches and flywheels etc and I wonder how you all know so much. I can take every last screw out of a macbook pro and put it back together with ease, but my tdi seems overwhelming to me.
I have a feeling that my intake manifold is quite dirty as I am almost positive it has never been cleaned in its entire 183,000 miles. I have almost forced myself to remove my existing intake manifold several times over the past several weekends to clean it, but then I stop myself. I stop myself because I say to myself, why would I spend so much time taking out the existing manifold, cleaning it, and then reinstalling it when I plan on upgrading as soon as I can afford to buy a pd150 intake. I am such a novice that I know it will likely take me several hours to disassemble and reassemble.
Overall I want to have nozzles, upgraded turbo, chipped, fmic, etc. upgraded air intake
To start with, rather than clean the existing egr and intake manifold, if I purchase a pd150 intake manifold and 2.5inch race pipe to replace the egr. I can also purchase the egr cooler delete kit from DG. I am concerned about my ability to get the stock boost elbow over the 2.5 inch race pipe, but I'm hopeful that after heating it up in an oven i can stretch it over the pipe for the time being. (I fully plan on upgrading all of the boost pipes when I install the fmic, but I plan to use existing piping for now)
So I'll have the pd150 and the race pipe to start with. I know I will end up with a cel at this point for the egr delete, but I don't care. My next plan after upgrading the intake manifold would be along the lines of installing the pd in tank lift pump and upgrading the nozzles. From what i've read, nozzles should come towards the beginning of an upgrade journey. I have selected the Bosio PP 764 nozzles. My concern here is with regards to the lack of tune at this point and lack of upgraded turbo.
Will I be able to upgrade to the 764 nozzles without a tune and without the larger turbo? I anticipate smoking and perhaps general issues with the way the engine runs at this point. Would I be able to get by with upgrading to these nozzles and simply adjusting the fuel using a vagcom?
So then naturally after I have upgraded the nozzles I would start planning an upgraded turbo and fmic. I guess I am trying to avoid having to pay for multiple tunes, ie RC1, RC2, etc and perhaps upgrade myself to a point where I can pay for RC4 one time when I'm ready.
Thanks for your thoughts guys
