Here’s the full scan:
Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 D HW: 03L 907 309 AA
Component: R4 2.0l TDI G000SG 9983
Revision: 12H16--- Serial number:
Coding: 0050072
Shop #: WSC 22251 004 1048576
VCID: 2F3B012FDB144EC2279-807A
VINID: 0E69DD70745AA15746080044004F18B3C9
3 Faults Found:
001025 - EGR System
P0401 - 001 - Insufficient Flow
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 36
Reset counter: 255
Mileage: 296639 km
Time Indication: 0
Date: 2063.14.31
Time: 18:28:22
Freeze Frame:
RPM: 1564 /min
Speed: 78.0 km/h
Voltage: 14.14 V
Load: 62.0 %
Load: 100.0 %
Mass Air / Rev.: 255.0 mg/str
Mass Air / Rev.: 405.0 mg/str
009231 - Exhaust Gas Recirculation System
P240F - 000 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 296982 km
Time Indication: 0
Date: 2063.14.31
Time: 22:25:21
Freeze Frame:
RPM: 2001 /min
Speed: 118.0 km/h
Load: 64.3 %
Mass Air / Rev.: 0.0 mg/str
Mass Air / Rev.: 105.0 mg/str
Mass Air / Rev.: 310.0 mg/str
Mass Air / Rev.: 435.0 mg/str
001164 - Sensor for Exhaust Flap
P048C - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 255
Mileage: 297104 km
Time Indication: 0
Date: 2063.14.31
Time: 00:02:17
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 13.00 V
Lambda: 1.6 %
Lambda: -11.0 %
Bin. Bits: 00001110
Voltage: 1.140 V
Readiness: 1 3 0 0 0
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-EC1-V4.clb
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 114B600C492400FA880C06E892190042A1000022
Shop #: WSC 00066 790 00015
VCID: 7EA5EC6B40FE774AFCF-802A
2 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 19
Reset counter: 89
Mileage: 287501 km
Time Indication: 0
Date: 2063.14.21
Time: 17:45:42
Freeze Frame:
Count: 0
Count: 32768
Count: 12800
Count: 16401
Count: 51003
Count: 1
Count: 767
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 296627 km
Time Indication: 0
Date: 2063.14.31
Time: 00:05:47
Freeze Frame:
Count: 16386
Count: 2
Count: 29184
Count: 16390
Count: 51968
Count: 0
Count: 256
Count: 2816
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 7N0 907 426 CA HW: 7N0 907 426 CA
Component: AC Manuell H20 0606
Revision: 00001002
Coding: 0010002002
Shop #: WSC 00066 000 00119
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 75B7F34775483412AD5-8020
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 N HW: 5K0 937 084 L
Component: BCM PQ35 B 122 1184
Revision: BG122001
Coding: AF380E1A802F3EC4008800C17000004449000086535D0520648020200040
Shop #: WSC 03682 003 1048576
VCID: 3D272B670D78AC52A55-8068
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 21041 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R02ZZ64 Dataset Number: 1KM003v__B_ 0047
Coding: 00004E42
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C21266316E2A55A92B-8068
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 B HW: 1KM 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--0000AL0U00
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME0C200B43ZZZP
Crash sensor for side airbag: passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME0F290A43ZZZ.
Rear Side Airbag Crash Sensor (on driver's side):
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME39492730ZZZI
Passenger side rear thorax airbag crash sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME6D002830ZZZE
Crash sensor for front airbag: driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME636F3C30ZZZO
Crash sensor for front airbag: passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME314E3530ZZZA
Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb
Part No SW: 5K0 953 507 BC HW: 5K0 953 549 E
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90440NBH001BU Dataset Number: 5K0953507BC D005
Coding: 108A140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_A05_VW32.rod
VCID: 72BDC85B0426232A887-8026
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0301536 FLE 20140313
Coding: 820000
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 12041403000424
Coding: 352002
VCID: 79AFFF7759D05072C9D-802C
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RPXLZ07
Coding: 0000002
VCID: 7EA5EC6B4CFE774AFCF-802A
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0811
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DD03B2CF6EBEA307-803E
Address 2E: Media Player 3
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0008208603
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW36.rod
VCID: 5BE385FFF3AC8262BB1-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000008596627
Coding: 000490
2 Faults Found:
66048 - Motor for Front Window Regulator
B11EC 54 [00001000] - Missing Calibration / Basic Setting
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 96
67589 - Turn Signal in Exterior Mirror
B11FD 01 [00001001] - Electrical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Reset counter: 196
Mileage: 250331 km
Date: 2116.14.01
Time: 11:21:49
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F3F771550907289D-806C
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0008215808
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW36.rod
VCID: 5CE186E3F6A2855AB2B-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000008214578
Coding: 000490
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 91
131072 - Rear Door Control Module
B11ED 04 [00001001] - Internal System Fault
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 144672 km
Date: 2075.14.19
Time: 10:12:24
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
Component: Radio Prem-8 H07 0009
Revision: -----12S Serial number: VWZ4Z7P3560403
Coding: 01000440040007
Shop #: WSC 00066 000 00000
VCID: 2B03153FE30C32E20B1-807E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 24
Reset counter: 59
Mileage: 250331 km
Time Indication: 0
Date: 2052.14.01
Time: 11:18:17
Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0592
Revision: 1B001001 Serial number: 00007665903557 Dataset Number: 5N0035729A 0001
Coding: 0A10030080010110
ASAM Dataset: EV_UHVUMI 001007
ROD: EV_UHVUMI.rod
VCID: 2E051C2BD09E47CA2CF-807A
End----------(Elapsed Time: 01:19, VBatt start/end: 12.6V/12.4V)-----------
------------------------------10 Faults Found-----------------------------
