HarlequinSyncro
Hi,
I've installed an Audi A6 2.5 TDi 5 Cyl (AAT code) into my Vanagon Syncro but have a little glitch with the throttle.
On very light throttle, the engine backs itself off back to tickover and once there I can very slowly fully depress the throttle to the floor and it makes no difference to the engine rpms.
However, if I back off the throttle manually and depress it again slightly quicker then its not a problem.
Also, I have the 2 plugs for the brake and clutch pedal switches currently setup so that the clutch (light brown plug) is looped and the brake (black plug) is open. Is this right?
Thanks in advance.
MG
Thanks in advance.
MG
