ALH does not have a HPFP.. it has an IP. they have NO check valve.Not sure but I think there's a check valve inside the hpfp, thats why when I bleed from the pump the problem seems less dramatic
Hard to describe but it's where all the videos shows it, I'm pretty confident that my check valve need to be tested.Theres no fuel pump on an alh. Fuel is pulled from the tank by the injection pump. Its a sealed system.
Where are you applying vacuum in the circuit?
No hpfp as mongler also stated. So your pulling vacuum pre or post IP (injection pump)?Hard to describe but it's where all the videos shows it, I'm pretty confident that my check valve need to be tested.
You most likely have a crack somewhere allowing air in, but no fuel out i guess.In removing the supply line from the tank outlet, I found an o-ring on the outlet. Never saw that in the Dr. Dan's video, Is there a groove, etc. it should be placed in? Is the check valve in the fuel pick up, or in the coupling to the tank?
There wasn't a brief back flow when I released the vacuum, it was a prolonged gurgling.
That said, the new tank pick up has arrived and I plan to replace the pick up, after drilling the check valve, and repeating the exercise.
All else considered, I successfully vacuumed the fuel line at the pump and ran it without issue. But, the next morning, the tube from the filter to the IP had a large bubble and it repeated the crank without start episode. All the hose fittings appeared tight. Is there someplace else I should be checking for leak(s) that would show up, overnight, between IJ and fuel filter?
Thanks, lots, for your views and advice!
mjb
This would have been a good question to post in the 101 or VE/PD categories.Update: Bought a used ALH from a guy in Lancaster, (86,000 miles) No flywheel/clutch. It's on an engine stand at this time.
Purchased a single mass flywheel/clutch combo and would like to change the Timing Belt/water pump, etc., before I install it in my Jetta wagon, but unsure how to find TDC. Can I position the new clutch without a bellhousing mark. For example, can I use the Camshaft lock tool and trust that the position will be adequate for the swap?
No I did not ......... mainly because I could not find one at any of the local stores in my neck of the woods.Didn't try a rotary wire brush like a bottle brush?
