Ferbie
Hi guys,
I've been searching all over the internet, this forum and vortex but haven't found a ton of info. So I'm really hoping you guys can chime in!
I was an idiot today. Jacking up a friends Golf (MKIII) and I totally put the jack in the wrong spot.... wasn't sure where it should go, the pinch weld was already really bent and mangled..... so I used one of those rubber looking pads on the bumped down floor panel (I hope you understand what I'm talking about). Like the part with the bumpy coating, there is a runner along the bottom of the car that is jutted down... I thought it was subframe.
Anyways.... you can probably guess where this is going.... jack went through floor..... i really ****ed up. There is now a jack sized hole up through the floor of the car and I don't know how to fix it.
Would fibreglass repair kit be the right idea? It's a curved down section, so a metal plate wouldn't really work... I thought maybe a fibreglass patch would do the trick... but not sure about strength and all that.
Any opinions, advice, help is GREATLY appreciated!!
