indysoto
- Joined
- Mar 14, 2004
- Location
- Eugene, OR
Would this work? Put a flat tiedown strap with cleat around egr intake, If runaway; then pop hood and pull strap tight?!(thereby pancaking the rubber pipe, thus closing the system?)
Great to know thanks Bill! TW My ECM Egr is within Factory Spec on the high side... 380mm was the high side if I remember correctCan you exit the car and pull that strap in less than a second?
The engine can severely overspeed in about a second if it not kept in check by driveline load.
If you suspect runaway, let off the throttle, leave the car in whatever gear it currently is in and hit the brakes. Steer to a safe location, turn off the key, DO NOT PRESS IN THE CLUTCH OR CHANGE GEARS, if the car does not die when you turn off the key, kill it by locking up the brakes.
Never shift and never push in the clutch during a runaway.
Diesel 101. Instruct your family.
Bill
If you would turn your EGR valve into a race pipe, leaving the ASV working you can have the best of both worlds. Takes about 2 hours and saves you the 100$ + you spent on the race pipe, and now you do not have to run around the car like a crazy man trying to shut down a run-awayThat is the function of a properly functioning anti-shudder valve in the EGR. Having said that, I have a race pipe. Brakes and gears will work for the manual transmissions. Its only a problem for the automatics.
Basically, by the time you get an automatic stopped, the hood open and enough nerve up to reach into the bay of a Diesel engine turning upwards of 6000 RPM, the engine will run out of oil (runaway fuel) or hydrolocked and stopped on its own.
If you own an automatic, its probably a good idea to keep a functioning EGR in place. If you are an attentive TDI owner, you will notice increased oil consumption that is your clue the turbo is possibly nearing end of life and should be checked for its health status. Turbo failure is the primary cause of Diesel engine runaway.
TW
But it only closes for a short time then opens back up againTurning off the key supposedly closes the ASV until the engine stops turning.
ASV stays closed until the engine stops, a member on here proved that by turning off the key while in gear on the highway. He reported that the flap stayed closed until the engine stopped turning.But it only closes for a short time then opens back up again
Its a butterfly so the load is placed on both sides. That means the net force to close it regardless of the pressure is the same regardless if its a runaway situation or not.I doubt the vacuum motor is strong enough to close the valve at high speed. I have photographic proof that it's insufficient to stop runaway - prev. owner's mechanic turned off ign but switched to N instead of standing on the brakes. 4 broken rods and huge holes were the outcome.
Would you mind posting a link to the thread? Wondering how he observed the ASV status on the highway... would like to duplicate.ASV stays closed until the engine stops, a member on here proved that by turning off the key while in gear on the highway. He reported that the flap stayed closed until the engine stopped turning.
You can hear the change in engine tone when the ASV is closed. Try it and see.Would you mind posting a link to the thread? Wondering how he observed the ASV status on the highway... would like to duplicate.
You can hear the ASV close after the engine stops running and you can run an engine output sensor test with the VCDS and hear it.But it only closes for a short time then opens back up again
Under normal circumstances, turning off the key will turn off the engine's fuel and ECU and the engine will turn off and and the car will slow down....true dat.There's a pretty easy way to test! Get going down the highway with moderate load/acceleration, turn the key off and see what happens!
It's not rocket surgery.![]()
