I wonder what would cause diesel fuel quality to improve? Improvements typical come at a cost. Consumers typically look at lowest cost. Individual distributors would loose sales if their diesel fuel cost more, based on consumer reaction. And there are no higher EPA/CARB/ASTM standard changes forcing higher quality. The attached below piques some thought:
The principle measure of diesel fuel quality is its cetane number, a measure of the fuel's ignition quality. Cetane number influences combustion. Requirements depend on engine design, size, nature of speed and load variations and starting and atmospheric conditions. A higher cetane number indicates that the fuel ignites more readily and burns more completely when sprayed into hot compressed air.
In the U.S., the Standard Specification for Diesel Fuel Oils (ASTM D975) establishes a minimum cetane requirement of 40. Most diesel fuel sold in North America has a cetane value between 40-45. Diesel engines operate best on fuel with cetane values of 50 or higher. To protect diesel fuel-injection equipment, ASTM D975 requires diesel fuel to meet a lubricity requirement of a maximum wear scar diameter of 520 microns in the High Frequency Reciprocating Rig Test (ASTM D6079).
This tells me higher cetane numbers has a return value. And the early VW CR-TDI's were designed for a maximum wear scar diameter of 450 microns. I'm not sure what the 2015 EA288 engine HPFPs are designed for regarding wear scar diameter, but the early (2009-2012) EA189 engine HPFPs were designed for higher fuel lubricity values than the US ASTM D975 regulations require.
The Cenex cooperative (where I currently get my Roadmaster diesel fuel from) went to this premium diesel fuel vs. Cenex's normal diesel fuel years ago, at a higher terminal cost, largely because they consume most of the fuel they purchase in their equipment, and the ULSD fuels were costing them downtime and maintenance repairs on their fuel pumps and injectors (so says the owner), and they rationalized the increased cost of the fuel would decrease the cost of their downtime and maintenance repairs (savings would more than offset the additional fuel cost). After a few years, the owner felt the premium fuel exceeded their cost savings goals, so they kept it and also offer it for sale on retail pumps for the general public to purchase. This is what I would call a study that provided at least this cooperative a cost advantage to have a premium diesel fuel. And, given their consumption level is high, so also they tend to have relatively fresh fuel in their pump tanks.
So I think there is cost value in premium diesel fuels, given the history of VW-Bosch HPFP failures (and the cost to repair, and the out-of-service time) and this cooperative example. Hence the reason for my inquiry. I agree with Lightflyer1 - there isn't much credibility in a fuel station attendant regarding giving you accurate information on their fuels - they don't typically know. And if they did, in weeks or months, they may change their source or quality of fuels anyway. No regulations exist to post fuel quality values on the pumps for the fuel in the tanks either. I guess I'll just have to accept the fact that "it is what it is" and move on.
