Sonia's_Driver
Yesterday I was driving to work and I needed to lower the window. I hit the auto down button for the driver's side, and I heard a crunch and the window motor working, but the window did not go down.
On the drive home, about 10 minutes into the drive, I hit a mild bump, and the window slammed all the way down. It was a very cold drive the rest of the way.
So, last night, I removed the door card, and managed to get the inside door panel off enough to remove with window from inside of the door. I managed to get everything reinstalled correctly.
Here is my question:
Do you think that the bolts that tighten the window clamps simply came loose, or do you think that the window was frozen shut so thoroughly that the clamps simply ripped off of the window? In the past, when the window was frozen shut, the motor would visibly and audibly struggle with the window, but it would remain frozen shut. Also, the freezing was usually obvious. This time, it was not apparently frozen.
Second part: do you think my fix will be lasting? Should I modify the window clamps somehow? Should I use some sort of treatment on the window seals? I have a bottle of Einszett brand Gummi Pflege Stift, but have never used it before - do you think that will do the trick?
Thanks for your advice.
Sonia's Driver
Sonia's Driver
