I have been using Valvoline Synpower PS fluid for the past 45K miles without any problem. Got it on sale at Checker for $1/qt.Shawnz said:Does the VW take some special power steering fluid like seemingly every other fluid on it? Mine is on the 'low' mark.
So is it a dealer only thing or is there some specification? Obviously I'm not going to go dump ATF in there. Can I hit checker and look for a 'VW approved' fluid?NB_TDi said:Yes VW requires special fluid. I had my rack replaced about 6 months ago because the PO used non-VW fluid.
Cough up the dough for the real stuff. It just isn't worth it.
http://www.tdiparts.com/catalog/product_info.php?products_id=408Shawnz said:So is it a dealer only thing or is there some specification? Obviously I'm not going to go dump ATF in there. Can I hit checker and look for a 'VW approved' fluid?
I haven't found any specification in the owner's manual.
They'll also tell you any ol coolant will work too.Shawnz said:Thanks. The Autozone guy assures me any old power steering fluid will do - lol. I'll probably be placing yet another order for stuff for the TDI.
PS steering resevoir is near coolant bottle. It is black with a green cap. You have to insert a quarter to turn cap.helloskyharbour said:Could you guys tell me where the resevoir is located on a 2004 BEW automatic Jetta? I am getting a bit of whining lately (60k miles) and would like to check the level.
That gets expensive so I use a washer/slug.2004STARWARSTDI said:PS steering resevoir is near coolant bottle. It is black with a green cap. You have to insert a quarter to turn cap.
