CoJoNEs
Yes I know the question has been asked 100 times, but unfortunately im stuck.
2002 Golf ~78k miles
RC2 chip, Sprint 520s, VR6 Clutch
just had a timing belt and clutch replaced by Jon Hamilton (rallywvw.com) at ~76.5k
Driving home from work yesterday everything was fine until get pull off off the exit ramp from the highway, notice the petal doesn't seem to do anything over ~2500 rpm, at this point there is no smoke. I was about 2 miles from home so I am thinking, great my MAF is failing I will get it home and do the limp test when I get there. About a mile later I get billowing white/grey smoke (hard to tell it was dark), but it was so much I couldn't see out my rear window. Eased off the petal and the smoke isn't billowing anymore, but its noticible. Pulled over the first chance I got, shut it down popped the hood, looked for anything noticible in the dark or anything other then the smoke, but nothing. Started back up, same problems, but made it home, just easy on the petal.
I seem to have the same symptoms as described here, complete with the whooshing noise
http://forums.tdiclub.com/showthread.php?t=123720&highlight=no+power+smoke
Here is what I have tried so far:
-- tim
- checked the hose to and from the intercooler and then everything connect along the intercooler pipe and from what I can tell everything is connected ok. I pulled on the area right by the clamps and it definately seems to be in there good.
- Checked the VNT rod for movement, I can push the rod manually without alot of pressure.
- checked the vacuum hoses on the N75 valve
- sucked on the vacuum line of the N75 valve to check pressure as I don't have a vacuum line test, how much pressure should this hold? there is suction there when I suck on the line, but I feel like it would take awhile for any real pressure to build up
- replaced fuel filter, I am almost due anyway, and read it could be related to the fuel sensor shut off? Is there a test for this? I can't seem to find it.
-- tim
