Hey everyone, looking for some help with a 2006 GOLF TDI with 170,000km's on it. Just recently the engine has displayed symptoms of losing power when accelerating hard - especially at around 80 km's. When I put the pedal to the floor it shifts down but actually starts to go slower. Is the engine going into limp mode at this point? The engine will throw a P0234 - turbocharger overboost. It doesn't code all the time but I'm starting to wonder if this is limp mode that it's going into even though it doesn't throw a code all the time.
Once the engine is warm, at an idle the engine stumbles and the rpm gauge bounces between 800-950rpm. But with excessive revving up and down it seems to clear itself up - blowing a bit of black smoke in the process.
I've changed the air filter, fuel filter, MAF sensor and the N75 solenoid valve with no improvement. Now I've directed my attention to the VNT actuator. I have a vacuum pump and am able to pump up the actuator and I can see the rod move and it is hitting the stop (it only moves about 8-10mm's though from what I can see.) Given that it's hitting the stop I assume it is adjusted correctly and is moving it's full amount. When I pump it up to 15 psi, it takes 75 seconds to bleed off to 0...is this normal? I have tried spraying lubricant on the actuator rod to make sure nothing is sticking.
Thanks for your assistance.
