Power folding mirrors
mayday_soc
RI
Mk7 TDI SEL
There are 5 different door modules available ending in 592/593 with prices varying quite a bit. Which door module is recommended for this retro fit?
I only care about folding/heat, I do not have blind spot monitoring. I have an SEL trim with lighting package (Ive read this matters). I might already have a 5 module on the passenger side because mirror dip works.
Is there a way to use VCDS to see which modules I currently have? It would be significantly easier than removing two door panels.
edit: If I had to guess (not the latest suppression) but they should end in either BZ00 or EZ00. They cover both 2dr and 4dr, as well as both LP and no LP. But the dates are a bit confusing as they over lap a bit. My build date 9/15 falls on both.
dwu.048
Richmond, BC
2015 Golf MK7 (DSG)
I know with using OBDEleven, you can check to see if it is a 3 or 5 module. If you have the 5 modules, then you just need to retrofit the switch, and the 2 folding mirrors.
mayday_soc
RI
Mk7 TDI SEL
VCDS told me everything. SEL trim appears to have 592/593 B modules. Crisis averted.
dwu.048
Richmond, BC
2015 Golf MK7 (DSG)
That's good. Just need to buy the mirrors with switch and program the folding mirrors with puddle lights. A fun mod.
DieselDavid
Maryland
2014 Jetta TDI 6M, 2015 Passat SE TDI 6M, 2015 Golf SEL TDI DSG
Here is a discussion on retrofitting the power folding mirrors. Most of the posts concern the purchase and a few post on the installation.
