RoeHaven
Forgive the long post, we all know how full of "personality" these cars are!
Over the passed few weeks I have had 3 separate instances where I have gone to leave work (either for lunch or to go home) and I am greeted with a rapid clicking/check engine light flickering and most dash lights on, while the key is in the ON position. The clicking is coming from the dash and not the engine. It tries to turn over but it just won't catch. I had it towed to my usual mechanic and they said that it was something electrical and the car wouldn't let their obd2 connect to it. (I somewhat feel they were full of s&%t) and they can't find anything that would cause a no start. The second time it happened we thought it might be my parking slightly nose up in the parking lot, as both times it occured i was parked this way. The second place we towed it to started the car up no problem after it was towed and their obd2 suggested it was dirty injectors. I use fuel additive regularly and we gave it a fuel filter change. It ran fine for a day after that and then it happened again, but this time I was parked perfectly flat, not nose up. I hooked my obd2 up to it and it has the reading of
PO638 Throttle Body Actuator Bank 1
J338 Implausible Signal
I've had multiple theories thrown at me, one being the battery which I got checked out and its fine. I removed the throttle body, cleaned it out and reinstalled and I'm getting the same rapid clicking and throttle body reading. Maybe the throttle body needs replaced, but I just want to see if this is what happens with the dash (rapid clicking) when it is a throttle issue or if it might be something electrical just leading me on a wild goose chase! Thanks all!
