KrashDH
Hey All;
It's been a wild ride over the last 11 years. I've learned so much from this forum. But my activity here is likely going to plummet. I've put a lot of blood, sweat, and tears into my own 2002 Golf 1.9 ALH Mk4, and hopefully provided some quality DIY and tech writeups for those to follow and current members.
It's an interesting point in life when you decide to pivot, especially after thinking you're going to run a car forever.
I just picked up a newer car, diesel, but an AUTOMATIC, which I've never owned in my life. That being said, the ONLY reason I chose this new rig was because it's one of the only ones that can be manual swapped at this point. So likely that will be in it's future. I can scratch the manual itch with the truck until then.
I don't know how I feel about parting with my Mk4. Sad actually. It's a part of me now, a lot of my personality is in it. There's really no value that can be put on that. In normal circumstances (if I had a house, kids, significant other, etc) I'd probably have no issue keeping it. It's not a financial thing. It's more of a "I'm a single guy who's renting and can't maintain 3 vehicles and 2 motorcycles on his own. And the new rig is going to demand a bit of attention from the get go.
Anyway, I compiled a small list of what I've done to the car, that started out bone stock since my possession:
I'm having a really hard time with this potentially letting go. I know it sounds like a sob story, but I don't go through vehicles like a lot of people. I get attached, put a lot of work in to making them my own, and want to upkeep and run them forever. This thread I really made for myself so I can come back and see what I've done later down the road. Maybe that's not the best though if I'm in a spot in the future to pick another one up (homeowner) I might regret if I end up giving this one up.
My time will now be spent on the new rig taking care of a few things that need to be addressed, then I will be trying to find parts from europe for the manual swap.
Until then, it's been a pleasure interacting with you all. I'll still check in so feel free to DM me
- GT 1756 Turbo (Xman)
- .230 Nozzles (Xman)
- Installed a BEW lift Pump
- Nicktane Spin on Fuel Filter
- 11mm pump (not 10 that come on the manuals)
- Full turbo back exhaust
- Taco Taco Intercooler
- Kerma lower pipe intercooler Kit
- Kerma Billet CCV
- PD150 Intake
- PD150 TIP coming from Cascade
- Franko Stage II cam and valve seals coming from Cascade
- Boost, EGT, Oil Pressure gauges (no dummy lights)
- Steering wheel 2 place POD
- Oil pressure gauge in vent pod that I 3D printed
- Bilstein TC's all around
- Audi TT bushings everywhere
- Rear beam R32 solid bushings
- MK6 GTI flat bottom steering wheel installed
- Android Head Unit
- Sport seats and I added the wiring and knobs for heating
- Front door card re-upholster with leather
- Front and rear cameras (back up in the lecense plate light one)
- 3d Printed relay cover to allow the OEM installation of the lift pump relay
- Additional fuse box so I don't have everything dangling off the battery
- Custom underhood lighting
- Upgraded (bigger) battery
- 3D printed fuse box tray for battery top
- Mesh ECU door for easy removal
- Projector retrofit with Morimoto D2S projectors. Fog lights in headlights on a euro switch, fog lights in bumper also controlled by euro switch
- OEM Hella Ballasts and Philips Bulbs
- GTI Tail lights
- 5th brake light mod
- Rear hatch wiring has been fixed the RIGHT way permanently
- Drivers side front and rear door microswitches have been upgraded with the revised and permanent switch that shouldn't fail
- 20% tint all around
