sn0ri
Hi all! I recently bought a <80k mi 2014 sportwagon from a family member after getting a new job with a 120+mi round trip commute which made me a bit suspicious of some easily fixable but annoying electrical issues on my ‘05 BEW Jetta (which is now with said family member and is re-purchasable in a pinch…)
I love the wagon and it’s a highway *monster* compared to my mkiv, but I want to make sure I’m watching the emissions system correctly. I’ve put around 800 miles into the wagon so far after driving it home last week (essentially all fed. highway at 75mph+ — I’m not a conservative driver) and I’ve noticed 2 active regen cycles before today, but they’ve lasted a *while*: 25+ mi driving at state highway speeds on the first (not sure when it started, but that’s assuming the start is when I noticed), and 25 minutes on the second after getting where I was going (parked and let it idle after realizing it was in regen). Currently sitting at my house after a rare local drive (around town <15mi) and a regen has been running for 15 minutes after parking.
I’ve read through the existing CJAA threads, re: maintenance and longevity, but a lot of them date from before the “fix. Is this duration and frequency on regens expected? Or should I be concerned? I know they’re more frequent after the fix, but I haven’t seen clear advice on “when to worry” other than checking for soot at the tailpipe and making sure the regens are happening at all.
In anticipation of needing to be vigilant, I’m getting a VAG-Com cable to look at the emissions blocks etc. I know the obvious response is to ask for VAG-com numbers, and I don’t have them yet. Wanted to post and ask before then (partially because I haven’t found a great source for normal (post-“fix”) behavior after searching).
(before anyone asks — I’m in Massachusetts, so the emissions system needs to stay intact, even beyond the warrantee. That’s why I’m planning around emissions inspection and maintenance so carefully…)
Thanks as always
Thanks as always
