drew1202
So when I changed my oil at 30k I noticed oil and the bottom of the drain pain and plastic shield. There wasn't much consumption, maybe about .5 liter over the 10k miles but I did reuse the washer and plug from before so I thought that might have been the cause of the leak. Well to be sure I got a new drain plug from vw with a new washer and called it a day. Well 3 days later and a couple hundred miles I figured I'd check out the pan again to be sure. Well there is still fluid down their but idk if it is from when the oil drained out and never completely dried or I might have a leak somewhere. Nothing noticeable from the plug itself but the foam insulation around the drain plug secretes oil whenever I put a towel to it. What should I do?
