ajfd
UPDATE:
The source of the problem was a fuel line that worked its way loose. The line is near the rear passenger tire.
ORIGINAL:
2012 TDI SEL, ~22400 miles, 45 fill-ups
I got a call from the misses a few minutes after she left for work this morning. She was approaching a stop sign when the glow plug light came on and the car stalled. After she came to a stop, she pressed the Start button. Car turned over but couldn't start. Very strong smell of diesel. Car had about 5/8th a tank of fuel in it.
I showed up a short time later and pushed the car to a parking lot.
Diesel all over the road.
Hooked up the VCDS while we waited for the tow truck and pulled the following:
Dealer won't get to look at the car till tomorrow.
ORIGINAL:
It also noted "09-Cent. Elect. -- Status: Malfunction 0010", but no faults codes found.3 Faults Found:
5227 - Fuel Rail/System Pressure
P0087 00 [101] - Too Low
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 36063 km
Date: 2019.14.21
Time: 07:47:40
5231 - Fuel Rail/System Pressure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 36063 km
Date: 2019.14.21
Time: 07:47:40
5523 - Engine Start Blocked by Immobilizer
P1570 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 36063 km
Date: 2019.14.21
Time: 07:47:40
Readiness: 0 0 0 0 0
