Kingcodez
Can anyone comment on the ECS kit regarding poly front bushings? I checked the rear LCA and it is destroyed. I have a set of TTs somewhere but I wanted to hear how the polys are working out. My springs are already hard and I'd like to have as much of a go kart like experience as I can.
I plan to replace whatever is on the LCA, the control arm end links, the thingie with three bolts, and probably the CV joints.
My car has 200k and coilovers, so I'm sure everything has been well railed.
Also, should I replace the rear stuff with poly units?
I know my bump stops are trashed, is there anything other than the stock yellow foam that I can put there? My shocks don't have enough dampening so they bottom out a lot.
Edit: in the rare instances that I'm going 90 and have to slam on my brakes really really hard, my car feels like a floating boat veering side to side. Is there anything I can do to keep the car going straight, or does it have to do with brake fluid issues or slightly worn discs?
