windaddiction
So my wife was driving, and the car threw a CEL, P0272. Now the OBD2 codes aren't very helpful, so I brought it into scan. My VW service guy did a good job and now the engine is fine 500 km later.
So they said this code is essentially poor cylinder pressure on #4. They explained there are 4 main causes,
-Bad glow plug ( they actually measure the cylinder pressure)
-bad injector
-worn cylinder or rings
-or... and i think a big or since it was just one cylinder... a bad HPFP ( which they confirmed for me is covered upto 100,000km )
What the tech did was move the glow plug from #4 to #3 cylinder. then reset the CEL. This will narrow down the issues and I thought was a great idea. If the light stays off it was probably a loose connection, if it comes back on but this time it is #3, that glow plug is bad. If it comes back and show #4 cylinder, then it could be low compression or a bad liner/rings.
As I am still good to go, I assume it was a bad connection, they only charged me for the scan and not changing the glow plug positions os i was happy, however I need to buy VAGCOM since I do own 2 TDI's that are both out of warranty now! Hope this will help some one one day!
tags po272 p0272 po 272
-bad injector
