You are just down the road from me. Well sorta... I live not too far from Benson.
I have been leaning toward replacing the clutch. I have 229k right now on the original. I might look into that after I get the timing belt taken care of. Not that I know a huge amount about any of this. I just scratch my head that the only time it happens is when it is hot outside. Thanks for your input.
Hi. Who is a good mechanic in central NC to replace a TDI timing belt? As I said, my clutch was operating OK, but really needed to be replaced (at least the spring portion) at a lower mileage that you're experiencing now. I don't know much about my car's early history -- I bought an '02 Jetta sedan new in '02, then that car was totaled by a drunk driver in November, '06; I bought my '03 wagon with 110K to replace it. It was a recently turned in lease car from California, it showed signs of poor maintenance and there was a groove in the carpet under the clutch pedal from the heel of high heeled shoes. I think it had had about 4 years of hard life.
I expect that if you upgrade your clutch to the most modern type of clutch in use today (my upgrade about 12 years ago was to a combination of V6 standard and racing parts, it's been really solid but it does away with the mass balancer and that results in noise with the clutch pushed in and the clutch engagement is rough and jerky -- I think that there are more recent upgrades that allow for a solid clutch with smoother and quieter operation. That said, I can't complain of getting 400,000 miles out of a clutch assembly with no issues other than a little noise and harshness), you'll find that all is well again.
Good luck, Bruce in Carrboro
