bhef
Hey all,
The other day when leaving for work, moving maybe 3MPH in first gear, I heard a loud pop sounding like I blew a tire. Checked the tire front right where the sound came from and all was well there. Called the PO and he told me this was probably a turbo hose getting a hole or coming off when I mentioned that my turbo and power is weak compared to before the pop happened. My gas mileage has improved considerably, however, I now smell exhaust when the car idles way more than before(maybe related?)
I have a VNT 17/22 and tune from KermaTDI. Have the 3 bar MAP sensor. Also, EGR deleted. No shudder valve either. Only about 40k miles on all of these components.
No CEL.
I've checked all of the intercooler piping/turbo hoses and even replaced the turbo hose right out of the hot side of the turbo as it was starting to be in bad shape. No changes in boosting after replacing. Everything else looks great. Made a DIY boost leak tester and when pressurizing the only thing that was leaking was the hose on the intake to the turbo. Tightened the clamp and that's better now. Helped startups go more smoothly, but still having power and boost issue.
I recently purchased a Ross-Tech OBDII to USB. When checking the MAP today it flatlines and won't go above 255 kPa or 2.55 Bar like stock would. All the sounds of my turbo are still there at the same timing corresponding to RPM and pedal position except quieter and the powerband feels like it's in the same places relative to RPM except weaker. Smokes a little grey smoke under WOT just the same too.
Does the VCDS program pickup on levels of MAP readings above stock? In other words, would it read boosting above stock when a tune is applied to the ECU with an upgraded MAP sensor?? Can a tune go bad and cause the ECU to revert to stock MAP settings?? What could that pop sound have been?!
I'm at my wit's end here. I've had this TDI for about 6 weeks and am relatively new to checking the turbo and associated components. Where to start and what to check would be helpful.
ANY insight/direction is GREATLY appreciated.
Please help me get this TDI back to it's great performance.
No CEL.
