Mwilliams91
Friday,01,March,2024,16:18:43:45900
VCDS Version: Release 23.11.0 (x64) Running on Windows 11 x64
www.Ross-Tech.com
Address 01: Engine Labels: 038-906-016-BEW.LBL
Control Module Part Number: 03G 906 016 AC HW: 028 101 223 9
Component and/or Version: R4 1,9L EDC 000DG 7551
Software Coding: 0050078
Work Shop Code: WSC 00066 000 00000
VCID: 6491BB1372408BEAABB-5184
7 Faults Found:
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
005712 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Torque: 141.5 Nm
Torque: 107.4 Nm
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
005687 - Powertrain Data Bus
P1637 - 000 - Missing Message from Electric Load Controller
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 16.0
001681 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Temperature: 5.4°C
Duty Cycle: 9.7 %
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.10 V
Mass Air / Rev.: 0.0 mg/str
Duty Cycle: 95.1 %
Bin. Bits: 00000000
Readiness: 0 0 0 0 1
www.Ross-Tech.com
7 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Torque: 141.5 Nm
Torque: 107.4 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 1.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 16.0
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 11001000
Temperature: 5.4°C
Duty Cycle: 9.7 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.10 V
Duty Cycle: 95.1 %
Bin. Bits: 00000000
