So is this the most pertinant thread for me to post my bus drama in? I got everything hooked up in the bus to the point that I should be able to take it for a test drive.... Pushed it out into the driveway and tightened up the bolts for the axles. All is set.
I test all the pedal to make sure everything seems good and the clutch pedal goes to the floor. So I get out and check the clutch cable tension, its really loose, I tighten it, all seems good. Push the pedal again, right to the floor. Come to find out the PO( a total idiot) somehow messed up the part that connects the pedal to the clutch cable. Get it all fixed, great, good to go.
Hop in the front seat again, clutch feels great. Proper resistance, smoothe pull. I start her up, still go. Go to push down the clutch and "grgrgrgrgrgrgrgrgrgr". I have throwout bearings issues.
So close... so so close.
