Harvieux
Fabulous input here, Brian. This may be a stupid question but, I too am far from a chemist. Would it be possible to reduce the methyl esters in the bioD to a point where the reduction of ZDDP in the newer oils will be less of a factor? Later!GoFaster said:For what it's worth, ZDDP is an extreme-pressure additive, a "last resort" lubricant that takes effect during starting (by sticking to the metal) and in situations where the hydrodynamic lubrication fails (insufficient oil pressure, insufficient relative speed between the surfaces to maintain an oil film, extreme-pressure line-contact situations at drive gears and between camshafts and flat lifters, etc).
That's an interesting explanation of the biodiesel-dilution situation, and it makes sense although I'm no chemist. One thing of note is that the amount of ZDDP in oil has been going down because either the zinc or the phosphate parts of it (or both?) are bad for catalytic converters. Being no oil chemist, I could see this going in a few different directions. Either the amount of ZDDP is being trimmed without substituting anything else (in which case any amount of "substitution" by biodiesel could dramatically reduce its effectiveness), or ZDDP is being replaced by some other compound that is polar (same situation as described in the article could still occur), or it is being replaced by a non-polar substance (but I doubt it, because it is the polar nature of these molecules that holds them "stuck" to the surface of the metal).
I wonder out loud if oil analysis would show this. I tend to suspect not. The ZDDP is still there, but its effect on the metals is being displaced.
